1 - 20 of 29 Posts
Hi all,
My 2011 SW has started spluttering when it performs a DPF regen - a couple of times now it has had a really rough, jumpy idle that feels at any moment it's ready to stall. I'm probably going to show my age a bit here when I say this, but it reminds me of the bad old days if you ran your car with the choke out too long and it started to hunt :biglaugh:
Up until now, when performing a regen it ran with no boost, sounded a bit boomy from the exhaust, and stank of hot oil - but otherwise was fine. Now I get all that, and a very lumpy idle too. It seems to drive fine while it is doing this, but come to a stop and the rev counter needle is noticably twitchy and you can feel the engine is running roughly.
So far I've ignored it given it only happens during a regen but what is a little odd is that it did it from cold this morning on the way to work. I thought they only ever ran a regen when warm, but there was definitely the usual signs of a regen (no boost and the boomy exhaust) even before the temperature gauge had got to the normal position. And there was this lumpy, spitty, slightly misfiry idle. By the time I had got to work it had warmed up, was boosting normally, and running perfectly smoothly again.
Any thoughts? I've yet to see any warning lights or errors up on the dash and it is currently running on Shell vPower diesel (if that makes any difference to a regen - since I bought it in April it has been fed Shell premium diesel with Millers ecomax additive).
Ta in advance! :beer:
It's just coming up to 80k.
My commute is a 6-mile jaunt into town though because of the time I go in, there isn't as much stop-start as there could be so it's usually on the move at a reasonable speed rather than crawling - and the coolant at least does warm through reasonably properly on the trip to work.
Once a week it gets a blast down a 10-mile stretch of dual carriageway when we go do the weekly shop and then every couple of weeks there is a 120-mile round trip on the motorway to see the in-laws.
It's done that regularly since I bought it in April and while I accept that's not usage usually associated with diesel ownership (I couldn't find a late petrol Sportswagon), it has been faultless up until recently.
There wasn't a hint of anything odd on the way home this evening and I've since been out in it to Uttoxeter, so a 50-ish mile round trip at speed down the A50 and M1. Behaved perfectly!
Hi TheCrust
Mine does something very similar and always has.
As you say, when the regen ocurrs and you're cruising along, it's only really noticable as the rev's approach 2k . This is most noticeable when you lift off the throttle to slow, and the revs start to fall - when they get near 2k the exhaust gets very boomy indeed :)
However, if you slow down to a stop and idle at some lights, mine has always fluctuated the revs in the way you describe. What I do now - is to lift the refs a few hundred rpm above normal idle, and then there's no more fluctuation and no concerns about stalling.
Rancid
  • Like
Reactions: TheCrust
Hello Rancid - it's good to know mine isn't the only one that does it, thanks for that. :thumbup:
I'm just really puzzled not only that this hunting is new behaviour so something has changed to introduce it, but by the fact I'm fairly sure it did a regen yesterday morning before it had warmed up - as far as I knew they weren't supposed to do that...
Oh well, we all know Alfas can be a law unto themselves sometimes, perhaps this is one of those moments :biglaugh:
I'm going to go back to the regular Shell diesel / Millers additive combo I used to use for a bit and see if it calms down.
Ta again!
Crust
it does happen at times, but should be very mild. uneasy idling as compared to lumpy...
My guess is this happens when the fuel trim is a bit off, ie you got fuel from another supplier with differing viscosity since the last calibration (every couple of hundred miles). EN590 allows for alarge variation in fuel viscosity - between 2.0 and 4.5 mm²/s. a lot of biodiesel content makes viscosity higher, less biodiesel makes viscosity less.
Since I buy branded fuel from the same supplier, this has all but gone.
Ta again!
Crust
Hello,
Reviving an old thread here, but hoping you can help. I have an almost exact issue with my 159 2.0 Jtdm. Did you ever get to the root cause of your issues ? Or can anyone else shed any light ?
I get an intermittent hesitation on light throttle that occurs for a period before going away for a while and then returning. Truly intermittent and im thinking it could be during a DPF regen. When the problem occurs if i pull over i get a very lumpy idle which has caused it to stall. During driving i get the hesitation only on light throttle and some exhaust soot plumes. Ive check all vacuum lines, all MAF, MAP, throttle valve and EGR are clean. My EGR is actually coded to remain closed, and logging on AlfaOBD confirms this. Although, will the EGR still operate during a DPF regen ? I only ever use Shell fuel, with miller additive recently, but the issue occurred before then.
Im also suspecting a fueling issue, as changing the fuel filter a while back seemed to cure the issue, but only for a month or so, then it returned. But the new filter cant be blocked already.
One very interesting thing, when the issue occurs with light throttle whilst cruising, i can hear what sounds like a metallic valve opening/closing abruptly. Now i cant get it to do this whilst stationary to see where the noise is coming from.
Its all a mind tease. urgh.
Appreciate any other insights people can add.
Tom
Might not be relevant, but my 2.0JTDm at 120k+ mile has started to regen every week (regular as clockwork at the moment, every Friday evening on a 120 mile motorway/fast A road drive) I do a stupid amount of around town during the week and then a blast of 120 miles Friday and Sunday without fail for 7 months during summer.
Currently it's doing my head in, the DPF is obviously in it's last throws of life (EGR been mapped out and closed for the last 4 years)
I'm going to take it off and either drill it out or replace with a straight through pipe.
I did that on my last 1.9JTDm with no issues so as long as I'm careful to not make it obvious I see no problems.
other than the eco police who think it's a good idea to dump the soot into the countryside in one big hit rather than a little at a time through the whole country :)
Axe
Alfa 159 2.0 JTDm Lusso 6sp.
….No problems?.... apart from you cant pass an MOT like that anymore (its no longer just a visual check to see the cylinder is there).....oh and there the minor detail of a £2000 fine if the authorities catch you on a spot check....which are getting ever more common...at least where I live.
….mine used to regen that regularly....until I started doing longer runs. The 2.0 regens more often than the 1.9 and 2.4 anyway to keep the DPF clean. One of the reasons its Euro 5 spec. Mine is at 150,000 with the original DPF with no issues. Download a DPF monitor app like i did and link it via a bluetooth OBD2...then you can keep an eye on the DPF clogging level and see how fast it cloggs and how clean it gets after a dpf. Also on these cars the regen period will shorten if you switch off the motor without the regen completing .It takes ten minutes on the 2.0....so even if you switch off at 9 minutes the next regen will be much sooner.
I can't see an issue with a regen every week, if its collected soot, its collected soot, especially if its all town work beforehand.
To the thread reviver.....although the EGR has been mapped out.....have you still got the manifold flaps in place?....if so, probably carboned up and not shutting or opening correctly.
Does the 2.0 still have the swirl flaps in the manifold ? I wasn't sure it did? What confuses me is that the car runs beautifully most the time, but then like a dog at intermittent times, which i *think* is when a DPF regen takes place, although it has happened before within 1 minute of starting and pulling away. What happens during a regen that would cause these issues ? More fuel i assume. Like i mentioned before, changing the fuel filter in the past seemed to cure it for around 3 months then it came back, surely the fuel filter doesn't need changing that often, unless my tank is rusting and pulling through too much shmutz. The last 2 weeks the issue hasn't occurred, but im sure it will return soon. I do 70 miles of motorways a day so has plenty of good runs.
Any help appreciated.
Our Giulietta runs better when doing a regen.
It pulls better, turbo spools up faster and the engine is quieter.
I wish it could be like that all of the time to be honest, only without the hefty fuel consumption.
Im still having these intermittent stutters and rough idles. The other day it was stuttering bad whilst in traffic and after parking up in a car park, it stalled, then wouldn't start for ~10 mins. Im trying to get some decent logs when the issue occurs, but of course intermittent problems dont occur at convenient times. Ive had the EGR out before and cleaned, however, i have been getting error code P0490 - Exhaust Gas Recirculation (EGR) valve control out 2. However, my EGR is coded shut and logging confirms this, so ive ignored this error. I dont want to be replacing a £150 valve when its not even being opened. Does anyone know if this could still be causing the stuttering ?
Also, for the first time, the last 2 days, the boost level wouldn't go higher than ~1bar, stuck solid despite full throttle, this suddenly fixed itself though.
Im also investigating the levels of vacuum and the turbo solenoid valve, some wynns turbo vane cleaner is also working its way through. It seems the problem could attributed to a thousand things. :grumpy:
Any help or insight welcome please.
Blank the EGR then! Most of this is because the EGR shuts during regens. I fitted a partial blanking plate to my Giulietta, harder than on the 1.9 but still doable.
Be aware, the EGR can still leak if coded shut, always get a blanking plate.
Easy...I did it on mine.....although a restrictor rather than a full block in my case. It blocks the pipe from the EGR to the manifold rather than the EGR itself...which as you say can't be done due to the shape of the EGR valve. Exactly the same effect though...Both types of plates are only a couple of quid on ebay.
I too have the same model (my second one) I love the car and in general its been reliable, but any issues have always been diesel related, which is why i will never get another diesel again.
Not helpful I know, just saying!!
Unfortunate…..based on this forum its seems that to 2.0 JTDm is about the most reliable with the least problems. I guess you can always get a dud one. That said Im looking as replacing mine with a TBI in the near future. Nothing wrong with the car.....just (hopefully) I will be doing a lot less miles....my high mileage being the only reason I bought it.
  • Like
Reactions: symon
1 - 20 of 29 Posts
