1 - 13 of 13 Posts
just put a s/s exhaust on. any other non expensive bhp upgrades out there ?? she quick but a little more responce never goes amiss. only had her 6 mthns so shes a s i got her bar the exhaust.
I suppose the usual....
Aftermarket matched manifolds
Platinum/Iridium spark plugs (more efficient spark than anything else)
Air filter
Cat back exhaust system
remap etc etc.
You wont realise the full potential of any modifications without a proper remap though as fueling will change according to airflow - air filters/exhausts all change it, an engine will self learn to an extent....But not give the proper gains without the fueling curve and remapped parameters to match it.
how muuch are re-maps ?? is it the same as a chip. can you remap or chip. i dunno ?? ha ha
You cannot remap the pre 2001 build V6 ECU's, they have to be rechipped. Remapping is the modern version of chipping - you don't do both (ok there is a scenario where you do, but for the majority this is true).
The output from the mapping is comparable whether its done via a remap of the existing EPROM or whether the data has been burnt onto a new chip and welded in.
I have Squadra ECU and 45mm intake runners. This increases low down torque, higher up BHP and deeper engine sound - but not cheap at about €550 but well worth it and would work even better with a good exhaust
Clovertech does cams for the V6, a proper inducton kit, head revisions, custom exhaust (to match your requirements) and the map.
How much power and torque you can gain depends on how much you want to spend.
Rolling road remap or chip circa £400 ish
I have used Squadra too for other Alfa's, much better than BBR.
If you can do without your car for a few days go Squadra, assuming you have a car Alfanige cant do
1 - 13 of 13 Posts
