· Registered
No i mean the wire that pulls the "throttle" (other end in gas pedal, other end in throttle body).
And i found out it my self.
There is a "u" shaped pin/socket which graps in to the wire core - in the wire core near the throttle body.
You have to pull this pin up and pull the cable core little bit more out, after that put the pin back on, and that is that.
Now that the throttle wire is tight as it should be - i gained about 10hp :)
