Greetings- I am in the process of replacing the two steel brake lines (rusted/leaking) that run from the front of the car , over the gas tank, and then into the proportioning valve at the rear of the gas tank. The problem that I've encountered is that these brake line fittings are machined differently at the bottom than "conventional" metric brake line fittings. This slight difference in machining causes the fitting to leak even when tightened down into the proportioning valve assembly. Any idea where to purchase a set of these brake fittings or a possible "workaround" to make the "new fittings" work in the old proportioning valve body? Thanks for your consideration. Paul, Providence, RI
