Unfortunately I only managed to get a couple of days' driving before the clutch servo started leaking and the brakes were just too bad. I have consequently decided to go straight into the transplant.
Idea is the following:
-2.0L Twin Spark engine keeping injection, full loom and ECU
-Alfa 75 calipers (front)
-2000 LSD
-recon clutch
Seems to be the tried and tested recipie so this is going to be a lonely thread! Later I will get seatbelts done.
If anyone can suggest something really good to do as its at the mechanics I'd appreciate it.
I will dual wire boot and bonnet as suggested on the forum!!
You'll need to change the uprights/ spindles to 1750/2000 versions to fit the 75 calipers.
I've got a spare set of calipers if interested.
DO NOT fit 1750/2000 uprights. 75 calipers only fit with 1300/1600 uprights, however you will require 1750/2000 discs
