Hello. I have a recently restored 16v engine, with almost everything changed. The problem is, that after the engine is up to 80c temp, if I rev hard, almost anytime after, I hear the sound of a tappet clicking in 0-3000 rpm range. If I rev higher, no clicking, and then even at idle the clicking stops, till it comes again 5-10 mins later. Any help welcome.
Are you sure it's the tappets?
Very common problem unfortunately with these hydraulic tappets. Any particular side or cylinder?
Were new tappets put in? What type/make? Maybe one has failed.
What about the cams?
When new cams are put in they 'mate' with the new tappets during the 20 min break in period.
Can you upload a video?
What's the oil pressure at idle hot?
I had a ticking noise at idle hot. Opened her up and found a concave tappet and bits of cam lobes around the engine:(
