I'm upgrading my 3.2 to eibach springs and will have 4 serviceable springs avaliable for £50 plus postage or distanced collection from mid Wiltshire.
cheers
Paul
Message sent.Hi,
cheers
Paul
Brilliant - thanks very much! I hope the brackets are ok as the rest of the car is remarkably rust free (says he before looking at the suspension turrets!)It’s not a problem. The base of the rear seat comes forward after you undo bolts at the front of the squab. Then there are two bolts that hold the back down, once removed you lift the seat upward so it comes out of the hooks that hold it. You’ll then need to remove the parcel shelf so you can see the tops of the shocks. The rear top mounts can be rusty and may not be salvageable which means you will need to search Alfa breakers or talk to Italiparts to see if they have any in stock as new parts are impossible to get. if your top mounts can be salvaged then clean them up and spray with hamerite to keep the tin worm at bay.
I find removing the rear c pillar trim is required to get the parcel shelf out and I drop the cross member onto a trolley jackIt’s not a problem. The base of the rear seat comes forward after you undo bolts at the front of the squab. Then there are two bolts that hold the back down, once removed you lift the seat upward so it comes out of the hooks that hold it. You’ll then need to remove the parcel shelf so you can see the tops of the shocks. The rear top mounts can be rusty and may not be salvageable which means you will need to search Alfa breakers or talk to Italiparts to see if they have any in stock as new parts are impossible to get. if your top mounts can be salvaged then clean them up and spray with hamerite to keep the tin worm at bay.
Thanks Mufasa,I find removing the rear c pillar trim is required to get the parcel shelf out and I drop the cross member onto a trolley jack
(4 x 15mm bolts - WD40 and then breaker bar to open them). Gives you a bit of wiggle when you try to take the bottom of the strut off the 'pin' it's on.
I did this on my donor car only yesterday.
I'd allow most of the day to get this done TBH, it's a faff no doubt
You just need to use a trim removal tool for the C pillar trims and pop it off at the fixing points. I had both mine removed only recently due to moisture getting in the back window and they came away very easily. Just take your time and work your way around them starting from the bit nearest the back door.Thanks Mufasa,
As I dont have the right lifting equipment, I’m getting the local garage to do the work after I’ve removed the rear parcel shelf. I think I can unbolt the seat back without removing the squab as I can reach the two bolts with a socket extension through the gap between the squab and the back.
Is removing the c pillar trim fairly straightforward?
cheers, Richard
If you do remove the squab (I would recommend doing so, then you can check and clean stuff.) Unbolt the seat back then replace the squab as something to kneel on, as there are some electric connections underneath.Thanks Mufasa,
cheers, Richard
There are no separate speaker grilles on my parcel shelf - just the fabric stretched over grilles cut into the shelf itself. No separate amp in the boot, and nothing in the ICS sound settings.3 ways to check if you have DSP.
In the sound settings on the ICS
Remove the cover to the left hand side of the boot and you will see the DSP amp sitting to the top of the cage
Pop one of the rear speaker covers off the parcel shelf. If DSP there will be a subwoofer there. If none, you dont have it😁
