1 - 20 of 26 Posts
fellow Alfisti......
My 166 needs rear lower wishbones but I can't find parts anywhere, tried Grandons (he checked entire ROI & UK alfa fiat psrts network & none available, he told me they were discontinued) tried mickgarage, premier etc etc but no luck.
Has anyone ever sucessfully removed & replaced the bushes from the rear wishbones ?
Anyone got spare 166 parts for sale ?
Thanks in advance folks
Administrator
You'd be better off having a look in the 166 forum. Plenty of suspension talk over there.
Try Don Baker for parts/advice as well.
D
Try The Lee man, they will def be able to find and fit it handy enough for you too.
Not sure if you can replace the bushes with OEM parts, afaik you have to replace the whole wishbone. Some owners used poly bushes (search for powerflex), but not everybody was happy with the result (and the noise).
I've read about someone in the same position as yourself around 2 months ago. There is a shortage. The thread outlined where they replaced the bushings with slightly oversized ones successfully... I’ll keep searching.......
This is the Merc Bushe part number
Mercedes part number.2013520027
I did them when I bought the 166 so had kept the info :thumbs:
Yes Mr Rory youre right , the Merc part is in mine and with no adverse effects and they are cheaper
Mr Fellow corkinian (berti!) If you need the merc part let me know I can see what they will cost from my Auto factor ! Not as cheap as 20 yoyo's though Rory ( if I remember ! ) then again I forgot I have alzheimers !:D
The merc bush (rose joint) is for the stub axle and not the wishbone but I think Mercedes retail them at 17 euro approx
So I was right and wrong!!! :)
1 - 20 of 26 Posts
