1 - 2 of 2 Posts
hi all,ive got a problem with ics,coming up with momentarily connection to air compressor,checked some fuses etc,i have no fan speeds and heater stuck on hot.anybody got any ideas,thanks
Been battling very similar the past wee while James.
The only air flow I was getting was when moving.
Can you hear the recirc flap move?
You have probably seems the other threads on here.
You need to get into the panel behind the wipers. I took the wipers off etc - hands too big etc.
Once in there I had a wiggle of wires etc and the fan sprung into life.
Put it all back together again and it stopped. Back & forward several times.
Today I eased the wires out of the connector and gave them all a good clean and tightened them slightly and a good spray of electrical cleaner.
I took the opportunity to lube the recirc lever arms whilst in there and check that the aluminium pipes were cold leading to the fan box.
I have put it all back together and it was still working just an 1hr ago. Of course only time will tell if this is fixed.
Must confess though - despite the pipes being cold, the cabin interior didn't seem particularly cold!!
Hope this helps in some way.....
1 - 2 of 2 Posts
