Well here I am changing my front lower arms on my 166 (again), and I seem to have mislaid my eLearn, so......
Does anybody know the torque settings for-
The front lower arm balljoint
The 2 bolts at the front of the arm that go through the subframe
The 3 bolts at the rear of the arm
The long bolt that attaches the strut fork to the lower arm
And finally, the track-rod end nut torque setting?
Many thanks in anticipation.....
Administrator
GT 2.0 JTS
Component
Fastening
Ø
Value (daNm)
Validity
FRONT ANTI-ROLL BAR JOINTS
Nut
M10
Front anti-roll bar side. 3.8 - 4.7
2.0 TS
2.5 V6
3.0 V6
Nut
M10
(Shock absorber fork side) 3.8 ÷ 4.7
2.5 V6
2.0 TB
3.0 V6
2.5 V6 CAE
3.0 V6 CAE
M10
Front anti-roll bar side 3.8 - 4.7
M10
Shock absorber fork side 3.8 - 4.7
FRONT ANTI-ROLL BAR
Bolt
M8
Front suspension frame side 2.7 - 2.9
2.5 V6
2.0 TB
3.0 V6
FRONT DAMPER FORK ON WISHBONE
Bolt
M12
Shock absorber side 11.7 - 12.9
2.5 V6
2.4 JTD 10v
3.0 V6
2.5 V6 CAE
3.0 V6 CAE
Bolt
M12
Lower track control arm side 8.6 - 9.6
2.5 V6
3.0 V6
2.5 V6 CAE
3.0 V6 CAE
Bolt
M12
Lower track control arm side 8.6 - 9.5
2.4 JTD 10v
2.0 TB
2.5 V6 CAE
3.0 V6 CAE
FRONT DAMPER
Nut
M8
Bodyshell side 1.8 - 2.0
2.4 JTD 10v
FRONT DAMPER
Nut
M8
(Bodyshell side) 1.7 - 2.1
FRONT DAMPER
Nut
M10
Mounting side 3.1 - 3.5
FRONT SUSPENSION LOWER LEVER
Bolt
M12
Shock absorber fork side 8.6 - 9.5
2.0 TS
Bolt
M10
Front suspension. frame side 3.8 - 4.2
2.0 TS
2.5 V6
3.0 V6
Nut
M14
Front wheel hub steering knuckle side 8.6 - 9.5
2.0 TS
2.4 JTD 10v
FRONT SUSPENSION SUBFRAME
Front bolts
M12
(Bodyshell side) 10.5 -11.6
2.0 TS
2.4 JTD 20v
2.5 V6
2.4 JTD 10v
2.0 TB
3.0 V6
2.5 V6 CAE
3.0 V6 CAE
Rear bolts
M12
(Bodyshell side) 12.4 - 13.7
2.0 TS
2.4 JTD 20v
2.5 V6
2.4 JTD 10v
2.0 TB
3.0 V6
2.5 V6 CAE
3.0 V6 CAE
Bolt
M12
2.5 V6
3.0 V6
FRONT SUSPENSION TOP LEVER
Nut
M10
Front hub steering knuckle side 4.3 - 4.7
2.0 TS
2.4 JTD 20v
2.5 V6
2.4 JTD 10v
2.0 TB
3.0 V6
2.5 V6 CAE
3.0 V6 CAE
FRONT UPPER SWINGING ARM MOUNT
Nut
M8
2.0 TS
2.5 V6
3.0 V6
LOWER WISHBONE FLEXIBLE BUSHINGS
Nut
M10
Front lower track control arms side. 4.8 - 5.2
Administrator
GT 2.0 JTS
Hope it helps, didn't have much time to add any message at the time.
