1 - 2 of 2 Posts
:( HELP.My 164 V6 1991 has developed a strange fault.The offside headlamp will only work on dim dip.The sidelight works fine there is no dip or main beam.We have checked all the obvious,i,e new bulb connectors,and have even discovered there was a break in the earth feed so replaced that wire.When fed direct with a power probe the light works fine.Swopping relays has made no difference either:mad: My friend has suggested that it could be the dim dip relay but where the hell is that?Any ideas,PLEASE.:eek:
the 24v has fuses for left high beam and one for right and also a relay for high beam, probably different layout on 12v. On mine high beam relay bottom of the three relays on left in fusebox and fuses numbered F5 and F6. Get a cardisk and it will save you lots of hassle.
Mike
1 - 2 of 2 Posts
