1 - 9 of 9 Posts
J
Dear All,
I have a problem with my 164 3.0 12 valve engine.
At lower revs ( untill ) 3000 it feels as if I get a ´push´in the back without stepping on the gas. The car does not do this always. Also sometimes when I want to take of after standing still the engine really protests and everything starts shaking.
Excuse me for my bad english.
All tips are very welcome. I already checked the hose behind the air meter,changed steppingmotor.
J
Discussion Starter #2
<blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:<hr /><font size="1" face="Verdana, Helvetica, sans-serif">Originally posted by jos:
<strong>Dear All,
At lower revs ( untill ) 3000 it feels as if I get a ´push´in the back without stepping on the gas. The car does not do this always. Also sometimes when I want to take of after standing still the engine really protests and everything starts shaking. Above 3000 revs everything seems perfect. Running idle the engine also behaves strange : Revs up and down between 500 and 2000 without touching the gas ! Strange thing is these problems happen now and than !?
All tips are very welcome. I already checked the hose behind the air meter,changed steppingmotor.</strong><hr /></blockquote><font size="1" face="Verdana, Helvetica, sans-serif">
Maybe engine mounts. Has the roof lining on bonnet showing signs of wear and tearing ? If you rev hard while stationary does the gearshift move excessively ?
Also check and clean all hoses, connectors on the AFM assembly, plenum and vapour separator (back of plenum).
J
Hello Michael.
Thanks for the tips ! I will check them out this Friday after work. I do not think the problems caused are related to the engine mounts.
I will change the AFM by a second hand one which I can borrow from a local Alfa mechanic to see if this can solve the problem.
But still it is strange when I am driving around at 3000 revs to feel this little push in the back. This only happens at a certain rev level. ( Always exactly around 3000! )
Anyway, I will check the hoses first. As my technical English is not so good I want to ask you what the ´plenum`is.
Kind regards,
Jos
From the big hose on the AFM keep going left and the large metal box connected to the shiny pipes is the plenum. If you have a leak of any hoses attached in that area it will be unmetered air, ie the ecu has not read it. Not a good thing.
Don't discount the engine mounts, bad ones cause excessive movement ( remember its a heavy lump of an engine) and can cause all sorts of problem, inc poor and erratic running.
J
Hello Michael,
I have checked all hoses in that area, but no result.....
I also changed the AFM but the problem is still there.
I do not think it is the spark plugs or the fuel pump because the problem does not occure above 3000 revs.
There is one more option : thes little black thing just beside this valve which opens if you step on the gas. Or maybe the injectors ??
Greetings Jos
J
Hello,
Thank you for your tips !
Will check things out within next week !
Jos
1 - 9 of 9 Posts
