What wheel nut torque should I be using? I've just had a tyre replaced and want the check that its been tightened properly.
I've searched, but can only find references for the 156 (98Nm steel and 90Nm alloy).
N
As tight as you can get it on the ground with a hand wrench, I'd say.
(Tight + 1/4 of a turn or something?)
My torque wrench is set at 100Nm, and I leave it at that for everything, steel or alloy, skinny or fat....
I bet the tyre places don't adjust their air wrenches specifically for particular models... :)
Hi dave_t
159 alloys 108-132 Nm.(eLEARN 2.2 JTS & 1.9 D DaNm 10.8-13.2)Frighteningly tight-if you don't carry a torque wrench in the car in the event of a puncture( I do.In 2008 I had three.)As our 147 values are 88-108Nm,I use 108 for both.
Thanks all :cool:
It looks like I'll go for 108Nm then, although that is quite tight so it looks like the torque wrench will be living in the car (as you say Sir Baloney)!
