Could someone please provide some info on how to remove the rear view mirror? Please see attached drawing from eLearn, any clue how to remove the part surround (1) and what it meant by the description in step (2)?
The area of the windscreen in front of rain sensor seems to need some cleaning as its fogged up.
Thanks in advance.
Thanks in advance.
!bump, I would need some instructions too. Please Help !
is this covered in the auto wipers delete sticky thread?
Thank You for your help, but in the "auto wipers" thred is not explained how to take off the mirror, just how to disconect it from the ECU.... I readed somwhere that the auto dim mirror has a different mounting location than the normal mirror, whitch sucks ! Will update asap as I get some more info.
Yes thank you for the info. I menaged to take off the in. mirror last night. Its fair easy > first off you need to take the rear cover off (with some flathead small screwdrivers) than you need to slide "DOWN" the mirror it self and it will come down. To instal the new rear view mirror, or put back the old one, you just go the opposite way, so to mount it you need to slide it from dwn to up.
It is confirmed the dimming rear view mirror with sensors needs to be mounted 4-5cm higher. Also if you are doing the retrofit on a windscreen that dont come ctock with the upgraded rear view mirror, you need to make some kinde od black foil to cover the mirror instalation.
Now from my prospective there are 2 ways to mount the new mirror, get a new bracket and mount it a bit higher, or take off the curent bracket somehow, and glue it higher.
Will post the resoult.
Thank you for the pictures.
Do you know if the cables needed for connecting up the automatic rearview mirror + rain sensor are present on cars which have the standard rearview mirror?
Mine has all necessary connections (you will be needing just 1, the white one), and it came with standard mirror, now I cant garanty that all 159 have the necessary connection. (you‚ll finde a connection after remouving the front light cluster). I‚ll make more dital pictures when I‚ll grab some time to deal with it.
Now I must fabricate a new mounting bracket, becouse the new mirror needs to be mounted 4-5cm higher. Checked on local scrapjards no 1 has a necesary bracket. Hopefully it is not so hart to manufacture. Cheers
