Morning all , had my recently acquired 159 aircon system filled with dye and it’s shown a leak in one of the pipes , now I know which pipe it is but how would I go about describing it to a breakers/parts supplier?
The leak is on the rubber part of the pipe pictured below , I think it’s the compressor inlet/outlet pipe .
Automotive tire Automotive lighting Hood Steering part Water
Motor vehicle Automotive design Vehicle Automotive exterior Vehicle door
The air con pipes which run from the compressor to the cabin are in 2 parts, you have the long section from the cabin which runs along the left hand side of the engine bay to just before the compressor, then theres a short section from there to the compressor, so you want the short section.
The short section comprises of the 2 pipes.
Getting that off the compressor Will be a job in itself, you might have to cut it off.
I might have the short bit in the garage, I'll have a look later
