HELP! I have a poorly 159 and not sure where to start?.
1, turbo whistle rather loud. Check pipes, slight stretch on intercooler bottom hose which needs replacing but can't find OEM or silicone replacement. Alfa will only supply with aluminium pipe from rear of turbo.
2, smoking from rear and loss of power, had terraclean to clear deposits from engine and DPF , also cleaned the mass flow sensor.
3, knocking from front nearside wheel. Replaced top upper wishbone and everything fine for couple of days now back with a vengeance although more like a creaking flex noise when accelerating and braking or car leaning into bend.
Any advice greatfully accepted :depressed:
