Hi all
I have a few issues on my 2.4 159 which I think are all related (new thermostat needed??)
1) The heating in the cabin takes a long time to kickin and when it does it works intermittently.
2) When I go up a steep hill the temperature gauge rises to 130. This is solved the first time by taking the foot off the accelerator – it goes immediately back to 90.
3) The overheating problem also occurred on the long run to Gatwick airport yesterday (150 miles each way). First time the temp started raising I took the foot off the accelerator and temp dropped immediately back to normal. Second time it stayed at 130 with the resultant power restriction until I stopped and turned the engine off for a few minutes. There are no other signs of overheating
4) Since the above two issues became noticeable, the noise from the fan coming in has become more audible.
Having read other similar posts, I think the thermostat needs replacing. However, could it be the rad or fan as well?
Thanks in advance
Thanks in advance
