Hi all,
I jus changed my selespeed pump n brake switch 2 days ago and all is fine.
Then today while I was slowing down at traffic light the gear suddenly dropped to neutral n I couldn't engage any gear at all. and check gearbox message appeared.
I tried to restart car n still same. Can't engage reverse or gear 1.
Car was towed to workshop.
Fault code is P2908 clutch sub-system n P0856 VDC Message from CAN.
Tried to clear fault but after starting car, check gearbox msg is still there n still can't engage car.
There was also no leak n selespeed pump seems to be working as I can hear the high pitch sound of the pump pressurizing.
Anyone help pls..,,
Thank you very much!
problem solved.
selespeed clutch bearing (Slave cylinder) fail and selespeed actuator clutch pump oil seal broken
Good you have solved the problem. In the UK I don't believe we ever got the 159 Selespeed - which accounts for the lack of response from the Forum.
My159 got the same problem, when slowing down or going to stop, sometime ( Not often) it will auto shift to Nautral but the screen still showing 1....is it also related with the selespeed pumb too? I have changed a new actuator, clutch, bearling and flywheel but still couldn't be solve....could anyone help me.....thanks!
