159
Electrics
Not starting
Not Starting
Central Locking - Windows Open
Alfa 159 central locking
Rear parking sensors
159 rear parking sensor problem
Rear wiper repair (Sportwagon)
159 SW Rear Wiper Motor Removal
Third brake light bulb replacement
third brake light - bulb replacement
Changing the cigarette lighter bulb
changing the cigarette lighter bulb
Heated seats
Things to check when Heated Seats Fail
Heater blower fault
Heater blower fan has stopped
HID beam pattern
HID Beam Patterns
Fitting heated seats
www.alfaowner.com
All windows not working
www.alfaowner.com
Vehicle protection system not available
www.alfaowner.com
Engine
3.2JTS engine
starting project 3.2JTS Q4 dual pipe exhaust
1750tbi engine
Guide - 1750 Turbo oil feed replacement (Revised Part)
Guide - 1750tbi thermostat replacement
Turbo whistle
www.alfaowner.com
Suspension
Rear suspension change
How to rear suspension change Part 1.
Front Subframe remove and replace - 159 & Brera
Guide – Front Subframe, remove and replace
Interior
Trim removal 1
159 Interior brightwork trim strip
Trim removal 2
How to change the interior trim....step by step..
Where is the Pollen Filter
where is the pollen filter located?
Wet footwells 1
Water in offside footwells
Wet footwells 2
159 wet carpet
Exterior
Windscreen rattle/dashboard fix
Windscreen or dashboard rattle - detailed fix with pictures
Boot badge removal
Boot badge removal help : 159
Designed Giugiaro badge fitting
Missing badges
Front bumper removal
159 front umper dismantle?
Rear bumper removal & parking sensor replacement - 159 SW
Guide - 159 SW Rear Bumper removal & Parking sensor...
Front bumper and headlights removal - 159 & Brera
Guide - Front bumper and headlight removal
Rear bumper removal 159 saloon
www.alfaowner.com
Lighting
HID Conversion
How to HID your 159/Brera....
HID Kit Bulb Colours
L.E.D Fitting - The full details
LEDs Advice for the 159
ICE
Radio
have lost TA on 159 radio!
Radio signal
Alfa 159 Radio Ariel Pants - SOLVED
Replacing the front speaker grill
How do you fit a front speaker grille??
Upgrades
After market ICE install
Can someone do a guide on "HOW TO INSTALL...
Suspension
159 TI Suspension Upgrade Advice
Brera
Exterior
Sunroof water leak
'06 Brera SV roof waterleak
Upgrades
Headlining colour change
Brera headlining colour change
Headlining for sky roof change
Removing Brera S headlining for SkyRoof
Electrics
Door mirrors
Wings mirrors do not close
Third brake light removal
Brera third brake light
Brera price list with options from April 2010:
Brera TBi v Brera 3.2S
946 Spider
Roof operation
Roof Operation Logic - Part one - fault finding
All Models
Vehicle Protection System Unavailable Bodge
www.alfaowner.com
Hidden features
Hidden surprise feature on my 159sw - list yours here
Turning off the alarm beep
Turn off the Alarm / Locking Beep Manually
Paint
Paintwork in tatters
Paintwork in tatters.
Electrics
Which battery
2.4 Battery Question - Which one?
Dead battery
Open boot with a dead battery
Heated seat repair
Changing the key fob case
DIY: How to change the 159 key fob/case
Qtronic stuck in park position
Qtronic stuck in park, problem & solution
Engine
Coolant plug leak
coolant level leak - part needed
Power loss with diesels
Power Loss with Diesels: Guide
Fuel consumption
159/Brera 2.4 Fuel Consumption
Hesitation 2.2JTS
2.2 JTS hesitation - now with new IMPORTANT information...
Diesel additives
Diesel Additives - Rhino
Glowplug
159, "glow plug pre-heating not available"
EGR cleaning
How To: 2.4 JTDm throttle body & EGR clean-out
Turbo control valve cleaning
Low rpm (lack of) performance
Air intake pipe loose and more
2.4 diesel engine running rough?
Exhaust fumes in the car
Exhaust fumes in car
Engine-shakes-when-starting
www.alfaowner.com
Heat Shield Clip
159 mystery petrol tank heat shield clip
Gearbox
Changing gearbox oil
www.alfaowner.com/Forum/alfa-159-brera-and-946-spider/368072-diy-changing-gear-oil.html
Air Conditioning
Aircon charge data
http://www.ictworkshopsolutions.com...013/03/Complete-Refrigerant-Filling-Chart.pdf
Steering
Correct Alignment in Post one
Steering Alignment (with Correct Data in Post 1)
Changing the Steering Rack Fluid
Steering rack issue
Power Steering Reservoir Diagnosis
Power steering fluid reservoir 2.4 jtdm
Tires
New Vredestein's for the 19"s
Tyre Wear
159 / Brera / Spider tyre wear issues - VIP - Revised...
Changing the steering tie rod
How To: Steering tie rod change
Front-wheel bearing replacement
Guide - Brera / 159 front wheel bearing replacement
Suspension
Knocking
Knock Knock..... yet another thread
Brakes
Brake switch fix
P0504 - Brake Switch
Interior
Steering wheel removal
Complete steering wheel replacement guide
Steering column switch repair
159 Brera steering column switch repairs.
Rattly boot release
HOW TO: Fix a rattly boot release (interior)
Steering wheel lock repair
[HOW TO] Fix/bodge the steering wheel locking mechanism
Removing the interior rearview mirror
www.alfaowner.com
Exterior
Wiper mount fix
Brera wiper eating itself?
Disable the auto wipers
How-To: Disabling the auto wipers on a 159
Scuttle blockage
SOLVED Rain Water Leak
Lighting
Fog light removal (all models)
How to change Brera Front Fog Light
Upgrades
QTRONIC - Retrofit Paddles
Retrofit Paddle Shift to 159 QTRONIC
Oil Catch can
Oil catch can
Oil Catch can (Diesel Only)
Oil catch can, how to
Clogz upgrade thread
www.alfaowner.com/Forum/tuning-and-upgrades/304828-clogz-brera-2-4-skunk-works-thread-29.html
External Links
Alfa 159 TI Full LED Conversion - Exterior Guide
Alfa 159 TI Full LED Conversion – Exterior Guide | Jabablog
Alfa 159 TI Full LED Conversion – Interior Guide
Alfa 159 TI Full LED Conversion – Interior Guide | Jabablog
Electrics
Not starting
Not Starting
Heated seats
Heater blower fault
HID beam pattern
HID Beam Patterns
retro fitting ti heated seats
As some will be aware I have started my 159 project (the car is a 2.4 Lusso 98 reg) and currently working in the cabin. I have been doing loads of prep work for the TI interior upgrade which includes retro fitting Ti heated seats. On the TI seats there are 2 x connector blocks. One is match...
All 4 Windows not working
Hello everyone I just bought a 159 1.9........ with a few issues :) .....how bad can it be ?! As per the Title none of the windows work, I have checked everything that I could thing about . The previous owner told me they all stopped at the same time The fuses are OK , i have 3.53V at the...
Need a help to start my 159 with the problem vehicle...
I was hit by a car,though it wasn't a fatal accident,but. The driver's door was affected,that made me pack my Alfa romeo 159 for 3months. After 3months my car refused starting,i replaced the old battery with a new one,it still can't start.if I insert the key what I see on my dash board is...
Engine
3.2JTS engine
1750tbi engine
Turbo whistle
Alfa Romeo 159 1.9 JTDM turbo whistle noise
Has anyone expirience with this. According to owner his Alfa Romeo 159 1.9 JTDM produces turbo whistle noise (bit quieter as it warms up but always audiable), for last couple of years and has done tens of thousands of miles like that, with no performance or oil consumption issues. Could it be...
Suspension
Interior
Trim removal 1
Trim removal 2
Wet footwells 1
Wet footwells 2
159 wet carpet
Exterior
Boot badge removal
Missing badges
How to: Remove rear bumper and tail lights, Alfa Romeo...
Here is a guide on how to remove the rear bumper on alfa 159 saloons. Removing the bumper allows access to parking sensors/wiring and wiring for the plate lights. Unless something is stuck, I estimate this to take around one hour. I know Chris did a fantastic guide for the SW, so I'll link...
Lighting
HID Conversion
ICE
Radio
Radio signal
Upgrades
Suspension
Brera
Exterior
Sunroof water leak
Upgrades
Electrics
Door mirrors
946 Spider
Roof operation
All Models
Hi, I did this a couple of years ago and documented the process with some pictures, but never had the time to write about it and ended up forgetting about it. Lately I've seen this issue resurface, so I decided I would tell how I disabled my electric steering wheel lock. I bought my 159 used...
Hidden features
Paint
Electrics
Which battery
Dead battery
Heated seat repair
Engine
Coolant plug leak
Fuel consumption
Hesitation 2.2JTS
Diesel additives
Glowplug
EGR cleaning
Engine shakes when starting - 2006 Alfa Romeo 159 1.9...
Hello Alfisti, I have been trying to resolve the problem of strong engine shake. The problem is mostly noticed during a cold start. The situation is a little better when the engine is warmed up. Otherwise, the engine has no other problems (for now). Excellent traction, no other problematic...
Heat Shield Clip
Gearbox
Air Conditioning
Aircon charge data
Steering
Steering rack issue
Tires
Tyre Wear
Suspension
Knocking
Brakes
Brake switch fix
Interior
Rattly boot release
159 - removing interior rear view mirror - how?
Could someone please provide some info on how to remove the rear view mirror? Please see attached drawing from eLearn, any clue how to remove the part surround (1) and what it meant by the description in step (2)? The area of the windscreen in front of rain sensor seems to need some cleaning as...
Exterior
Wiper mount fix
Scuttle blockage
Lighting
Upgrades
Oil Catch can
Oil catch can
External Links
