The Airbag failure warning light has come on in my 2007 Alfa 159 2.4 JTDM.
With MultiECUscan I get the following description of the failure:
________________________________________________
The Passenger Airbag Disabled- indicator light/circuit has a defect. Check it for opens, shorts and weak connections. Verify the light reacts correctly to the switch selection. MAKE SURE that the switch is returned to the position the vehicle operator expects it to be.
FOLLOW THE AIRBAG DIAGNOSTICS SAFETY PRECAUTIONS!!
WARNING: Improper access to the Airbag circuitry may cause the Airbag(s) to deploy or malfunction later, which may result in serious injury or death.
DO NOT MEASURE OR CONNECT ANYTHING TO THE AIRBAG SIDE OF THE CIRCUITRY without consulting the appropriate service literature first. Follow the local regulations concerning Airbag system repairs
The reason for this fault is that ECU has received very high signal from the sensor. The fault is present now. Take appropriate action to fix this sensor fault. Dashboard warning light was not activated for this fault.
_________________________________________________
I have attempted to delete the error but it is not possible. I have tried to change the interior light unit (where the airbag exclusion light is located) but this made no difference. I checked the connections to the ECU and the passenger airbag switch and cleaned all connection, but the failure is still there.
Any other suggestions? Should I replace the ECU?
