Hi all
My daily 159ti has sat at home all week with elecrical woes.
Last week coming home the engine hesitated momentarily a couple of times before the warning lights started: ABS, VDC and hill start unavailable. I've tried driving it for short distances since and the ABS seems to trigger on some or all brake applications and the speedo needle keeps flicking around although the speedo seems to be reading normally in between. There are repeated hesitations.
Fault codes are:
P0380 preheating control (replaced along with all the glow plugs four months ago)
P0504 Brake switch
P0500 Vehicle Speed Signal (CAN)
D602 CAN Line Error, Bus Off
9033 RH Stop Light, O.C. Or S.C. To +Batt.V.
D602 CAN Line Error, Wiring Faulty
Is this typical of ABS faults in the unit or a sensor? Do I have a wiring problem and if so where is it likely to be? The ABS fuse is intact, the large plug on the unit is clean and the brake lights work normally. The switch above the brake pedal looks fine and fiddling with it makes no difference. The battery is very new and there's plenty of power for starting after five days without using it. I've not changed the radio or any other accessories.
If I need a new ABS unit does it need to be coded and if so how and where?
Any help gratefully received
Many thanks
Fault codes are:
P0504 Brake switch
Many thanks
