I have the above vehicle which suffered poor starting, which got progressively worse.I have the car in my local garage who have always looked after the vehicle. They hooked it up to their diagnostic equipment and the fault code P0340 was reported (Phase Sensor). They fitted a new phase sensor, I collected the car and it started and ran fine for approx 3 starting attempts. Then poor starting returned. 5 different sensors fitted, new battery fitted, ECU sent off for testing NO FAULT FOUND, wiring check carried our ok, crankshaft sensor disconnected (IMMEDIATE NEW FAULT CODE) and it would not start at all. When the vehicle actually starts it runs fine, and sometimes starts OK, and then won't, always returns the same fault code running out of ideas, Help, please, thank you.
