I have recently had my clutch changed on my alfa and now I have the following problems that I hope someone can point me in the right direction with. The clutch was changed by an Alfa specialist and it will be going back to them on Thursday but I would like to have some idea on what could be the problem in case they try and fob me off.
1. From a standing start it takes almost 3000 revs for the car to get moving (forward or reverse).
2. When changing gear there is a lag (sometimes 1-2 seconds) from the gear changing on the dashboard to the engine putting drive to the wheels. When it sport mode the gear change speed is the same timing as it would be in normal mode, whereas before it was super fast.
3. When stuck in a jam the stop start nature of the jam means after 30 minutes I can start to smell the clutch getting hot!!
