1 - 2 of 2 Posts
Hi everyone, on the way home this evening my steering became very heavy, the battery light also came on. I have since read that it’s most likely the auxiliary belt. I get that makes sense. My concern is the belt running up over the PAS pump seems under tension. Is the PAS pump driven by a separate belt?
Thanks for your help.
With engine running is belt moving? I would hazard a guess the crank pulley has failed because as far as I recall from Vauxhall days 1 belt drives the lot.
1 - 2 of 2 Posts
