Hello I have put up a similar thread on the AROC forum so sorry if you have read it before. I have a 98 156 2.5 V6 which is being turned into a rallycross car the engine has been stripped down cleaned and refitted last week it turned over and started then died. I have replaced the relays and fuses that had blown but now the car won't turn over.
The fuel pump primes the key code light goes out there is power going into the ignition but not to the starter motor nor to the positive side of the battery the battery is fine and also some of the engine sensors have no power to them. I am thinking that it needs a new ignition switch and I'm also trying to locate the fusebox B98A but I'm not having any luck could someone please help
Many thanks
Lewis
Many thanks
Lewis
