1 - 1 of 1 Posts
Evening All,
Before I start, I know there have been loads of posts about sticking gear levers due to the gear shift plates / bushes wearing over time. I have this problem with my 2.5 V6, although to be honest I am not 100% convinced that this is the problem.
I have exactly the same fault as what a lot of you folk have had, whereby the lateral movement on the gear stick is like "stirring porridge" - it doesn't want to centre itself and is pretty much rock solid, although backwards and forwards movement is perfectly fine.
I done the usual procedure earlier, removed the battery and the tray and had a look at the shift mechanism. I removed the long bolt (17mm nut) with the two bushes, and re-greased it, and put it back together. It is still no different, if anything, the gear movement is stiffer, although this time I can get it in 6th gear!
If I move the gear shift mechanism backwards and forwards (from under the bonnet), there is a healthy clunk as the gear stick moves, although to get a sideways movement is an absolute pig. I really am stuck because I can't get my head round it. The two plastic bushes what the long bolt goes through are fine, they haven't broken down or fell apart or anything, although I have noticed that there is a spring that sits behind that 17mm bolt which is rather slack - I am guessing that it's this spring that controls the return movement if the gearstick is moved sideways. I think this is where the problem could be, but cannot find the part on Eper. I have also looked for the gearshift plate on eper, but to be 100% honest, I'm not entirely sure what I'm looking for. If any of you guys have a V6 and have the part number for this, please do share it with me, as this is a really irritating problem that I can't see myself getting to the bottom of !
Thanks In Advance,
Tony.
1 - 1 of 1 Posts
