Hello All,
I need new wiper blades all round for my interior facelift 156 Sportwagon (2003).
I had a quick look on Eurocarparts and there was a dizzying array of choices.
Which precise make and model would you suggest and is Eurocarparts the best place to buy?
Thanks in advance.
I use ecp quite a lot. Only ever had one issue, with a lower suspension arm
Boche are a good make I believe. Measure what you have on the car first and look at the 'fitment detail' tab so you're sure what to buy. Ecp are usually good at return/replace and theres usually an outlet not too far away, though in the current situation posting is your only option (unless you're a key worker apparently)
Bosch appear to be the best right now. I just use the old fashioned frame type blades. AFAIK, Champion is the only brand to still offer a curved passenger side blade but the performance with Bosch is better. If changing from a curved blade to a straight one, it may be necessary to adjust how the passenger side blade sits on the sponsor to reduce it parking on the plastic scuttle trim.
