I Have been told than the suspension on my 156 will need replacing before the next MOT. it is a 2002 and has done 115K miles. What bits am I likely to need to replace or should replace when they do it.
Also I always wanted to uprate the shocks and springs so seems like an ideal time, any suggestions for between £300 - £350 ish?
And while I am here anyone remapped the 2.0ts? any comments on that and will it put much extra stress on the engine. Would I need to upgrade the air filter etc to get a better gain?
Wishbones / drop links / ARB are likely worn components.
I fitted a similar kit to my V6 & had no issues, behaved well on a track day too :D
Remap probably not worth it TBH, spend dosh on better braking :thumbs:
Hard to say without inspection, take for a pre MOT check up mebee?
Only reason I changed mine was to lower / stiffen the ride, but found a bust spring while doing so :eek:
