My speedo was dicky.
Just did not react quick and has now been changed but the prob is still there.
You are traveling along at say 70 then brake and it takes a second or 2 for the speedo to drop.
Any ideas what the prob could be?
V
Aha, mine does this and gets stuck around the 60mph mark, only when the speed is falling though, not rising.
I assumed the ballsitics of the meter were sticky!
Maybe it's actually to do with the control signal going into it?
Any ideas anyone?
Speedo feed is from the ABS ECU.
The problem could be in there.
Mine is going in notches but I can't believe that is normal. Both the 147 and 159 I have had as courtesy cars dint do it.
If it normal I may have to buy a road angel just for the speed reading.
