1 - 20 of 99 Posts
Easy.
1st, make sure you have purchased the correct replacements: H6W (nothing else will fit properly)
2nd, remove the rear caps from the inner light units.
3rd, look inside for a plastic tab, that is the back of the sidelight holder.
4th, gently pull it out. It won't come out far, the cable isn't very long.
replace bulb & refit.
The bulbs have offset pins, so will only fit one way round.
Yes I have done mine, its a pig the side ligth bulb is in the centre of the light unit and you get to it from the back, undo the main cover and turn a small plastic lever to extract the bulb, the unit then pops out and you change the bulb in the holder, refit is opposite. Expect to donate some of the skin off your hand to the cause:cry:
It is tight, use a mirror was the advice I got and it did help to see in. Only needed it for the first change until you know what you are doing.
Have fun.
thew advice was super...but the bracket has broken off....any ideas please?
or do i have to remove the headlamp...if so how?
unfortunately I have broken off the plastic tab.....any suggestions...do i need to remove headlamp....alfa garage has quoted £235 to replace it!!:
Did mine recently, right ball ache. Especially with my fat fingers and :thumbs:!
Found that a connector came off the back of the main beam as well, which I had to clip back into place.
One of the worst cars I changed a bulb on was a Nissan Micra, that was tight!
just doing this on mine - the small bulb is a ***** to get out of the holder?
do i just yank it out? seems to have small notches on the side of the bulb clipping it in, didn't want to force it incase i damaged it - advice apreciated :D
(got the fitting out ok :thumbs:)
NO
It is a bayonet cap fitting.
So push in slightly then turn anti-clockwise.
yeah its not coming out with lots of pulling tho!
kinda looks like... (excuse ASCI drawing lol)
___
(___)
1 - 20 of 99 Posts
