Hi my 2004 156 Selespeed has an intermittent problem. When I stop the car and leave it for about an hour the gears won't engage. I also notice that the pump does not run when I open the door on these occasions. If I lift the bonnet a hit the plastic cover of the engine management ecu all is good and I'm on my way. It's doing my head in, can anyone offer advise.:confused
Pump
Replace with new one, or if you're adventurous replace the brushes in the motor.
Check/Replace the relay too.
Well money and time has hinderd me from purchasing a new pump and now the problem is getting worse. After about 15 mins of driving the selespeed light flashes and will not change up. If I happen to be at lights lke I was twice this week I have to open the bonnet and beat f*^k out of the plastic casing which houses the resvoir. Do we all still think it is the pump cos I am taking it off the road some to work on some issues.
Thank you all for your help.
