Hi, bought a 156 ts a couple of months ago with a worn but working up (+) button on steering wheel. Over a couple of weeks it became harder and harder to find the sweet spot on the button to get it to work. Now it doesnt work at all, no error lights, everything else including the down button work fine. Any ideas, advice welcomed with thanks!!!
Hi, yes stick changer working fine, thanks for the reply. is there a factsheet on taking it apart or is it a case of just following my nose?
I've never removed a Sele wheel, but a standard one is easy enough. You'll need a long allan key, with some kind of bar to give you leverage, to remove the airbag (disconnect the battery for ~1/2 an hour first), and a 24mm (IIRC) socket to remove the nut in the middle of the wheel.
There will be some additional connectors to detach for the sele buttons, but they should be obvious(?)!
