1 - 20 of 20 Posts
· Registered
As title says.....What could this be......Clutch, does it need calibrating..?
· Registered
Discussion Starter · #4 · (Edited)
When at traffic lights or pulling away at junctions...If's fine the rest of the time going up and down the box...
If you pull away gently it's fine.....As we have only just bought the car its all a bit new to us....
· Registered
Discussion Starter · #5 · (Edited)
I drove it yesterday and didn't have an issue..So went out with the wife and it did happen...I think its because she wasn't giving it enough revs.....She needed to drive it harded I think as it now doesn't happen if you put your foot down a bit.....Your really do need to learn how to drive a Selespeed.....
· Registered
Discussion Starter · #7 ·
Still not sure if this is right so going to get her looked at by a specialist.....Its still jerks/judders in first gear when pulling away so maybe it needs calibrating...Was told this needs doing every year.......
· Registered
Discussion Starter · #9 ·
If you're close to Swindon, get in touch with Smaky on alfa156.net. He'll sort you out. :thumbs:
Thanks for that...I have tried to register on there a few times but keeps saying my email has been blocked so can not register..
· Registered
Discussion Starter · #12 ·
Cheers DaveC...How did you do that...I'm in...
· Registered
Discussion Starter · #14 ·
Must be....
Logged in now and sent a PM top the chap you mentioned...Thanks...
· Registered
Discussion Starter · #18 ·
Thanks for the contact....Off to see Smaky today...What a decent chap....
· Registered
had a abarth selespeed not quite the same but similar was all or nothing first used to leapfrog , i used to wait mins till revs droped then slowlly till into second and was fine also gearbox was allways better when i switched to manual in first then was fine allways better in manual mode and didnt drink as much 2.4 nightmare getting it on aramp but fantastic cruising you can calibrate clutch for about 50 quid but cluch should last till 90 000 anway
· Registered
Discussion Starter · #20 ·
Worse possible outcome I think...New clutch and gearbox needed................Bottom...
1 - 20 of 20 Posts
