To fix or not to fix 156 sele TS
First is the slight crunch from 2nd to 3rd gear since the gearbox was re calibrated. Is it a calibration issue? Does the clutch need replacing as the car has done 78,000 ish. Or is it the dreaded synchro s meaning lots of money.
Second is a wierd brakes issue. The pedal went to the floor and braking was very poor. Slowly got it home and thought to pump the pedal a few times and they came back to life. No leaks under the car and reservoir is on max. Is it the master cylinder finished?
Opinions would be gratefully received.
