Hi everyone,
does anyone know wher i can buy the gaurds for my 156 rear disks they are pretty rusty and need replacing
Cheers,
Colin
Main dealer parts dept would be the first stop...
Are they actually falling apart though or just a bit of surface rust?
C
From memory I don't think they are the easist things in the world to replace.
yeah the the drivers side rear one, there was a load of rust on the wheel and i thought the pads were shot but i changed the pads last night and they wern't too bad but the gaurd was falling to bits, there is a couple of holes on it!! a bit surprised to be honest as its only a 05 plate and the other 3 just have surface rust.
do you need to take the hub off or is it just screwed on?
i think i might just put it to the garage up the road to get it done
Problem will be the small bolts holding the shield to the hub will probably snap off as they tend to rust in quickly ...
Depending on the shape of the shield, and most importantly the hole in the middle, the hub probably will have to come off .
