1 - 16 of 16 Posts
ok so the radio a blauplunkt vancouver cd36... don't think thats stock :confused: i've tired swapping the 12v wit the ign wire no joy....any ideas ??? Should i just drop kick the blauplunk or does this happen in all 156's, its my first and its a joy :) please help me :thumbs:
Banned
The stereo is not stock, so if it doesn't work then it's not Alfas fault, but has the fuse blown? Does it light up?
ok sorry didn't explan that post great . . . radio work fine just won't switch on and off wit the ign :cry:
I will have a look - there is a way around it, as when I fitted a Sony unit to my old Ford Focus, there was the same issue, and there was a way of doing it - as i changed it so that it switches off with the ignition.
Discussion Starter · #9 ·
the cig lighter :thumbs: will it be heavy on the fuse though :confused:....... thanks for the help lads its appreciated :)
Discussion Starter · #11 ·
perfect, tommorow evenings project.... just finshed fixing my rev counter tonight, thats on another tread ...Gift :thumbs:
not heavy on current draw, so not a problem. we are talking about an 'electrical trigger' to turn the headunit on/off. the main power still feeds via the 'constant' +12V wire in the factory radio plug.
so you need to connect the RED powerwire (usually called 'ACC' (ACCessories)) on the aftermarket headunit to a suitable 'switched' +12V wire (ie: 0V with ignition key off, and +12V with key on), like the cigarette powerwire.
leave the YELLOW 'constant' powerwire from the aftermarket headunit connected to the alfa radio plug. it should be connected to wire #7 in the alfa plug (ie: YELLOW goes to #7 for the 'constant' supply).
some alfa's do have a switched wire at position #4 in the same radio plug, but i figure yours does not. if there is a wire there, then use a multimeter to confirm its function before connecting it up. you should also do the same (ie: use a multimeter) for the cigarette wire before connecting things up. there are probably 3 wires to the cigarette lighter: 'switched' +12V, GND, and illumination.
btw, for peace of mind and safety, worth adding an inline fuse for the wire connecting to the cig wire. something like a 1~3A 3AG glass fuse.
Discussion Starter · #16 ·
all done :D perfect now, i'll probably drop in a line fuse when my ipod cable arrives, cheers for the help :thumbs:
1 - 16 of 16 Posts
