1 - 16 of 16 Posts
Hello everyone,
I just purchases my first Alfa last week end :)
156 sportwagon 1.8 2001, so far been great, my only concern is that when I am in traffic the temp gauge go up to 90 within few minutes, is that normal for an Alfa ?
Thanks for your help
It should go to 90 fairy quickly.. and stay around there.. it usually hovers between 80 and 90... How fast exactly does it climb to 90?
Sitting at 90 is normal, dropping below that on the move indicates that you need a new thermostat.
How low does it drop?
THanks for your replies,
It goes from mid 50's to 90 in about 2-3 minutes.
when driving along always stay at mid 50's only go to 90 when in traffic .
is the thermostat quiet easy to change or it is one of those fiddly job that required monkey arms
thanks
thanks,
order the part, looking forward for a fun week end. Still have to find out where it all goes
thanks guys
hiya,
fitted the thermostat, pretty easy job.
Now, i let the car run for few minutes, temp gauge goes up nicely within few minutes , but doesn't stop at 90, it just keep on going.....
one thing i have done, only realised after, when i added some coolant, i forgot to mix with water. Is that could be the reason ?
thanks
thanks
How hot did it get?
Any signs of the fan starting?
What condition is your rad in?
i stop the car when it reach the next mark after 90, didn't hear the fan kick in.
should i keep the coolant cap open while the car on idle for a bit ?
haven't been for a drive yet.
Have you got a test meter?
If you do, check the resistor module on the fan housing next to the top hose.
Discussion Starter #16
just to let you know,
did let the car idle again, gauge more settle at 90 ish, went for a quick drive, gauge drop slowly mid 80's.
look more like it now :)
thanks
1 - 16 of 16 Posts
