As some of you might know, the 156.net forum is no more. We knew that the site was going down for a while (lack of traffic) so I took the opportunity to save some of my (hopefully) useful threads.
Remove innner part of n/s drive shaft.
Remove oil seals
Remove diff cover
Remove diff. NOTE: There is a shim between the casing and the offside diff bearing. Do not loose it and remember to put it back in when you re-assemble it. I zip tied mine to the oil seal to remind me.
Remove diff
Undo the 3 x 10mm bolts holding the oil seal around the input shaft and remove the seal
Remove the gear selector mechanism. (3 x 13mm bolts) I took a load of pics of this as I intend to write a how to guide to cure the still gear selection problem)
Discussion Starter #2
gear selector cable doodahs:
stand the gearbox on its end - bell housing down (I didn't at this stage as I was still draining oil out of it.) And unbolt all the 13mm bolts holding the outer casing onto the bell housing:
Then remove the 17mm bolt near the nearside engine mount that screws into the gear clusters inside. (I'll get a pic tonight)
In theory, you slide the end of the gear box off the bell housing, leaving the gears mounted on the bell housing.
Hi Chris, Thanks for taking the time to save these threads. your content has always been an excellent resource.
  • Like
Reactions: Chris155
Here here. Super work Chris! Thank you, absolutely vital works of art!
  • Like
Reactions: Chris155
Hello, i just found this topic and it will be very useful this week: i just bought a 3.2 gta gearbox to fix from a scrapyard, only the 4th speed can be put in gear, any other one according to the seller
sorry for poor english, i'm in france, i would like to share the teardown with you, do i need to open an other topic ?
thanks
