1 - 11 of 11 Posts
· Registered
Hi all,
We have a 2003 reg 156 without a locking wheel nut key, therefore I'm having the local grage remove the locking nuts, but need to get a replacement set (so I can actually get the wheels off if I get a puncture!)
Problem I've got is that I can't get a set in any of the local motor factors......
Halfords list a set, but have none in stock, however, they list one part number upto 2002, and another 2003 onwards?? looking online there seems no difference, all adverts just say "all models".
they're 16" teledials on the car and I can't imagine I'm the first person to need a set of locking nuts!
Any advice gratefully recieved, if there is no difference between early and late models I can buy them off the shelf on the way home!
Cheers in advance!
· Registered
The Pre 2002 set will have a 19mm hex head.
The Post 2002 set will have a 17mm hex head.
What size are your other wheel bolts?
· Registered
Cheers, I'm not sure what size the others are, I'll check when I collect the car tonight (it's at the garage)
so if the size of the head is the only difference that won't affect me because it's locking nuts which will have their own key anyway :)
I may just be able to get the other pre2003 ones anyway.
· Registered
The key for the locking nuts will either have a 17mm hex or a 19mm hex.
Ideally you want the same size hex as the other 16 normal wheel bolts on the car otherwise it just becomes awkward.
· Registered
I support David, and furthermore, get rid of the lock wheel bolts, they are a pain...one day you have a flat in the pouring rain in the middle of the night and you cannot find the key.....
· Registered
Discussion Starter · #6 ·
Ah true yes, I would need a second socket if they were different sizes. I hadnt realised that because our other motor is an old mud plugger in which I just carry a cross brace with different size sockets on, but I dony want to have to start carrying more in the Alfa!
I take your point, there's little point in securing the alloys, they're not in amazing condition and I wouldn't have thought they were worth nicking. So the next question is....does anyone have 4 ordinary wheel nuts for sale?
· Registered
Don't believe that.
Someone tried to take a 4 1/2" x 13" steel wheel off of my Fiat Cinq once...!!
After that the Cinq got the old locking bolts from my 156 which needed new longer ones with the spacers.
· Registered
Once you know which size you need, let me know and I should be able to find either a set of ordinary or a set of lockbolts, whichever you want.
· Registered
Ditch the lock nuts, no one steals wheels anymore do they ? This isn't 1982 :lol:
Mine went ages ago, and I won't be the only one to have done it :thumbs:
Surely any motor factors should carry at least the right size nuts
Don't buy any wheel nuts because your car uses bolts...!
As for nobody nicking wheels, the case I mentioned above was only 6-years ago.
1 - 11 of 11 Posts
