Hi all, my remote key had stopped working some time back......only boot remote worked and then that stopped working also. The red light used to come on the fob when you pressed the buttons. All stopped working , tried a new battery....no joy.
That was about a year ago......made enquiries about a replacement key ( I only have one ) and the dealer cost was prohibitive. I used the key manually, unlocking doors and starting no problem. I was never happy having one key and decided to fix the remote and then perhaps get a non remote spare .
I Recently bought a repair kit expecting that possibly the switches had packed up, apparently a common problem . It came with a new plastic case, blank key blade, two replacement swicthes and a new battery. 20 euro ....good price. I took my own one apart, the switches seemed to be working , you could feel them click positively, decided i needed a very fine soldering iron and a magnifying glass to replace them, would get one later . Assembled the old circuit board and key blade in the new case , battery ect and thought no more. Noticed the red light on the fob did not come on when you pressed a button. Presumed it was not working.
Next day , went out to the car to go to work, manually opened the door, alarm went off, haven`t heard that in years, discovered the remote was working for the door locks and boot release with the expected noises beeping and car hazard lights working for on and off.............he but the car wouldn`t start. I suspect I have upset the programming. I had a quick search through the forum and tried switching on and off several times ( sixteen ) and tried removing the battery in and out a couple of times. Car still wont start . It is a reliable starter and has never failed to start only since now when I interfered with the key. Made alternative arrangements to get to work and will search the forum later more carefully for info .
Anybody out there with the programming info ?? I`m grounded at the minute and need the car to get to work. Its an `04 facelift 156 1.6 Lux.
Any help appreciated..............Dannyboy.
