my 2000 156 doesn't display either a code light nor injector light please help:oops:
First off the JTS wasn't available as a 2000 model car. Do you have a solid red key version or a flip black key car?
Does the car have a multifunction display in the pod for the air vents at the top centre of the dashboard?
Sorry for slow reply. I think the bulbs in rev counter for the engine management and CODE system have blown. The rev counter bezel is secured with a Philips screw at 12 o'clock underneath the top (use short screwdriver) and the the rev counter is secured by 3 Philips screws (use long screwdriver but magnetise it first so screws don't drop down). The bulbs are 1.2 watt instrument panel bulbs integrated into plastic housing. The are available from auto bulb specialists. You will need a proper driver to twist them or needle nose pliers for removal and refitting.
I'd try that first before looking for any other possible issues.
