Hi all,
I don't have a good feeling about this but figured I might aswell post a question.
The variator is totally finished and I have the constant dieselsound. Besides that I have something very
similar like this:
https://www.youtube.com/watch?v=ItA-by93M3U
Maybe not as loud but comes and goes at certain rpm's and also seems to depend on different engine loads.
So, what do you think?
Regards
Marcus
If the variator has been changed then it's a possible big end bearings....Hopefully you caught it in time. Time to pull the CAT, and sump off to inspect.
Hi Ronantu,
The variator is not replaced but is ordered along with all the other parts required for a cambelt replacement.
I have experienced bad variators before but not one that makes this kind of noise. Is it even remotely possible that it is the variator making this?
So, I finally pulled the engine and found that cyl 3 and 4 bearings has spun. However, the crank looks good in both positions. Can't really feel any scoring. Nr 1 and 2 had some wear on the shells.
First time for me inspecting a crank thats been subjected to failing bearings. Is it a definite case for the machine-shop? Measure and regrind?
Also, the crank pulley bolt, is it left-handed? Loosens clockwise?
