1 - 2 of 2 Posts
· Registered
Anyone know if it's possible to decat a JTS? Obvious issue is the 4 lambda probes, wouldn't want the engine light on all the time. Maybe there's a way to "fool" them?
On a similar note, has anyone figured a way of solving the poor connection problems with JTS lambda probes, maybe by cutting off the standard connector and using terminal blocks / soldering the wires together?
· Registered
You can use a decat manifold from older ts engines or a decat manifold from supersprint again for ts engine. Then you should use a new catalyst like the ts because the jts have precats and main cat together. Then with the help of an extension you can use all 4 lambda. Good luck.
1 - 2 of 2 Posts
