Hi
Have a big problem I cant crack on a 156 JTS .... after missfiring for a while intermittently, but always when cold ..... this has ground to a hault . Checked everything , spark fuel pressure ect , car runs fine when carb spray is squirted in. Checked the output on the ECU to the injectors, this is Ok for 5 or 6 cycles then the output dissapears ???? any ideas is this due to another sensor ? or a safety feature ... what is the knock sensor for ?:
Big thanks if you can help
Thanks for the response .... I had discouted the crank sensor as it sparks fine and runs when carb spray is squirted in ? are there 2 sensors ? 1 could be Ok and the other duff ?
