HI,
I've just ordered the elearn cd's but could do with a quick answer if anyone has one.
My internal blower isn't working, making driving in this weather almost imposible with the windscreen misted up.
I've checked the fuses under the dash and they all look good! The climate control dials are all on and I can alter the settings but not air flow!
My engine was recently replaced and I don't know if it has worked since then (I've been out of the country, wife has had the car)
I'm not even sure where to access the fan to check the conections, so any advice would be appreciated.
Thanks.
passenger footwell, remove material under glove box there are two bolts, and hey presto the main fan housing is there
there are several threads about the same topic on this site.
fan is remove dby taking out ONE 10mm bolt & rotating it CW
restistance is 2 ohmns
if it owrks on speed 4 but not speed 1 2 or 3 the resistor pack is burnt out.
