over the last week or so, my car has become a little harder to start.
seems to take a few more "turns" to fire up from cold, and seemingly a couple more turns are needed every couple of days, so it's taking a while. drives fine, no lumpy idle or anythign once it's going, but it's taking longer.
obvious check is the battery, which is warranted, but what else could be causing the problem?
occasionally when it's started from hot, it was start literally instantly, but then idle very low until the accelerator is tapped, then behaves as normal.
