1 - 12 of 12 Posts
has anyone stripped these down into component pieces for cleaning and how/where do you get the items need for coding the door locks to the keys
any help appreciated
I have removed the door locks. removed the three small screws but cant figure how to dismantle the rear piece of the door lock
Are you talking about the lock barrel in the door? Or the locking block? (3 screws in the side of the door)
The locking block is held in by the locking rods from the lock to the handle outside and the handle on the inside and from the central locking solenoid with another lock rod . they are all on those flick and turn plastic clips.
The lock barrel has a metal U clip that you need to pull off it will be very stiff. It slides between the door and the barrel.
Is that any help or have I misunderstood the problem??
The doorlock is not coded the car is. If you have the canbus on the later face lift you will possibly need to do a proxy alignment if you change them.
The only coded bit is the key. This is coded to the car.
yeah the lock barrel in the door. ive had removed it from the car.. want to strip and code the barrel to the key pattern but having trouble stripping it after removing it from the car and removing the lock from the handle itself
No 156s have CANBUS, only 147/GT.
Has it not got a small circlip at the back end? I cant remember TBH.
I know its more money but is it not better to replace all the barrels with a lock set then change the internals of the key ??
  • Like
Reactions: maxiboy wales
There you go maxiboy its even more straight forward :thumbup:
Thanks Davffc, I didn't think they did but was not sure about the facelift models . Cheers :thumbs:
reason for stripping was to clean and make up a spare set ready for fitting as the others are still fitted and i don't want the car off the road so was making a spare set for a quick turn around
Are you talking about the key or the barrel.
If you have the key and need a barrel, you should be able to order one ,or possibly get a local locksmith to make one.
Same would apply to the key.
Do you have the early red key or the later flat blade pop out key?
  • Like
later pop out keys. will give the local alfa place a call and see what they can offer
Offer to relieve you of lots of cash probably ...
1 - 12 of 12 Posts
