I was doing some work on my 156 with the front wheel off today and I stupidly managed to snap the pin off that holds the front disc in place. It is the part labelled 1a in the pic. It was a bit of a challenge getting the holes lined up together on the wheel, disc and hub but I managed to get the wheel back on and everything seems secure enough.
My question is how ok is it to drive like this? I can probably use a screw extractor tool to remove the broken part and replace it with a new one, should I remove the disc to do this?
Any advice would be greatly appreciated.
Andrew
Andrew
