Simple enough, will an early model rear door fit my facelift 156?
They look the same but do they fit the same?
Here's hoping...
Yes, but when it has come up before (and it has several times!) I've a feeling it has been mentioned that an electrical connection may be different.
L
if you can get a door from a '01 onwards pre-F/L car you won't have any wiring loom issue, unless your car has elec windows & the donor doesn't. does that make sense?
pre '01 the door connection was a 'push in & twist' type, after '01 they were 'push in & slide up a clip' type.
Pre face-lifts will have a differnet texture door panel.
