could any 1 help,me i have a 156 with a engine problem :mad: and have been offered a 146 engine :D and wood like 2 no if it will fit in my car they r both 2000 cc 16 v but have dif engine codes any help will b grate thanks
The basic 2.0 lump is apparently the same ,a 155 is also good, you will have to swap sensors to make all the ecu work to the same standard, and a few sensors are not needed on the new 156 ecu, I have had to do this myself and has involved me in a lot of work but interesting!:)
if the 146 engine is the plastic topped engine it will fit straight in. If not it will need lots of swapping over of parts.
Only the airfilter box of the 146 2.0 is different from the 156
try modifying the 146 intake for use in the 156, far easier to change filter.
